Programming A Molecular Relay for Ultrasensitive Biodetection through (129)Xe NMR.
Publication Type:
Journal ArticleSource:
Angew Chem Int Ed Engl, Volume 55, Issue 5, p.1733-6 (2016)Keywords:
Crystallography, X-Ray, Limit of Detection, Magnetic Resonance Spectroscopy, XenonAbstract:
<p>A supramolecular strategy for detecting specific proteins in complex media by using hyperpolarized (129) Xe NMR is reported. A cucurbit[6]uril (CB[6])-based molecular relay was programmed for three sequential equilibrium conditions by designing a two-faced guest (TFG) that initially binds CB[6] and blocks the CB[6]-Xe interaction. The protein analyte recruits the TFG and frees CB[6] for Xe binding. TFGs containing CB[6]- and carbonic anhydrase II (CAII)-binding domains were synthesized in one or two steps. X-ray crystallography confirmed TFG binding to Zn(2+) in the deep CAII active-site cleft, which precludes simultaneous CB[6] binding. The molecular relay was reprogrammed to detect avidin by using a different TFG. Finally, Xe binding by CB[6] was detected in buffer and in E. coli cultures expressing CAII through ultrasensitive (129) Xe NMR spectroscopy.</p>
