The structure of the ankyrin-binding site of beta-spectrin reveals how tandem spectrin-repeats generate unique ligand-binding properties.
Publication Type:
Journal ArticleSource:
Blood, Volume 113, Issue 22, p.5377-84 (2009)Keywords:
Alanine, Amino Acid Motifs, Amino Acid Sequence, Ankyrins, Binding Sites, Crystallography, X-Ray, Humans, Ligands, Mechanotransduction, Cellular, Models, Molecular, Molecular Sequence Data, Mutagenesis, Site-Directed, Protein Binding, Protein Folding, Protein Interaction Mapping, Protein Structure, Tertiary, Repetitive Sequences, Amino Acid, Sequence Homology, Amino Acid, SpectrinAbstract:
<p>Spectrin and ankyrin participate in membrane organization, stability, signal transduction, and protein targeting; their interaction is critical for erythrocyte stability. Repeats 14 and 15 of betaI-spectrin are crucial for ankyrin recognition, yet the way spectrin binds ankyrin while preserving its repeat structure is unknown. We have solved the crystal structure of the betaI-spectrin 14,15 di-repeat unit to 2.1 A resolution and found 14 residues critical for ankyrin binding that map to the end of the helix C of repeat 14, the linker region, and the B-C loop of repeat 15. The tilt (64 degrees) across the 14,15 linker is greater than in any published di-repeat structure, suggesting that the relative positioning of the two repeats is important for ankyrin binding. We propose that a lack of structural constraints on linker and inter-helix loops allows proteins containing spectrin-like di-repeats to evolve diverse but specific ligand-recognition sites without compromising the structure of the repeat unit. The linker regions between repeats are thus critical determinants of both spectrin's flexibility and polyfunctionality. The putative coupling of flexibility and ligand binding suggests a mechanism by which spectrin might participate in mechanosensory regulation.</p>
