Structure of Arabidopsis thaliana At1g77540 protein, a minimal acetyltransferase from the COG2388 family.
Publication Type:
Journal ArticleSource:
Biochemistry, Volume 45, Issue 48, p.14325-36 (2006)Keywords:
Acetylation, Amino Acid Sequence, Arabidopsis, Binding Sites, Catalysis, Coenzyme A, Crystallography, X-Ray, Histone Acetyltransferases, Models, Molecular, Molecular Sequence Data, Nuclear Magnetic Resonance, Biomolecular, Protein Binding, Protein Structure, Tertiary, Sequence Alignment, Sequence Homology, Amino Acid, Structural Homology, Protein, Substrate SpecificityAbstract:
<p>We describe X-ray crystal and NMR solution structures of the protein coded for by Arabidopsis thaliana gene At1g77540.1 (At1g77540). The crystal structure was determined to 1.15 A with an R factor of 14.9% (Rfree = 17.0%) by multiple-wavelength anomalous diffraction using sodium bromide derivatized crystals. The ensemble of NMR conformers was determined with protein samples labeled with 15N and 13C + 15N. The X-ray structure and NMR ensemble were closely similar with rmsd 1.4 A for residues 8-93. At1g77540 was found to adopt a fold similar to that of GCN5-related N-acetyltransferases. Enzymatic activity assays established that At1g77540 possesses weak acetyltransferase activity against histones H3 and H4. Chemical shift perturbations observed in 15N-HSQC spectra upon the addition of CoA indicated that the cofactor binds and identified its binding site. The molecular details of this interaction were further elucidated by solving the X-ray structure of the At1g77540-CoA complex. This work establishes that the domain family COG2388 represents a novel class of acetyltransferase and provides insight into possible mechanistic roles of the conserved Cys76 and His41 residues of this family.</p>
