Structural insights into the stabilization of MALAT1 noncoding RNA by a bipartite triple helix.
Publication Type:
Journal ArticleSource:
Nat Struct Mol Biol, Volume 21, Issue 7, p.633-40 (2014)Keywords:
Base Pairing, Base Sequence, Crystallography, X-Ray, Humans, Hydrogen Bonding, Molecular Sequence Data, Nucleic Acid Conformation, RNA Stability, RNA, Long NoncodingAbstract:
<p>Metastasis-associated lung adenocarcinoma transcript 1 (MALAT1) is a highly abundant nuclear long noncoding RNA that promotes malignancy. A 3'-stem-loop structure is predicted to confer stability by engaging a downstream A-rich tract in a triple helix, similar to the expression and nuclear retention element (ENE) from the KSHV polyadenylated nuclear RNA. The 3.1-Å-resolution crystal structure of the human MALAT1 ENE and A-rich tract reveals a bipartite triple helix containing stacks of five and four U•A-U triples separated by a C+•G-C triplet and C-G doublet, extended by two A-minor interactions. In vivo decay assays indicate that this blunt-ended triple helix, with the 3' nucleotide in a U•A-U triple, inhibits rapid nuclear RNA decay. Interruption of the triple helix by the C-G doublet induces a 'helical reset' that explains why triple-helical stacks longer than six do not occur in nature.</p>
